Reid Racing Flat Top Extreme Duty Dana 44 Knuckles | Pair | Ford Q&A
I have a 74 chevy dana 44 front axle with rcv's and was wondering if these would fit and would the rcv slide through the center hole? I don't mind converting everything to ford from the knuckle out as long as the rcv slides out the center hole, Chevy knuckles don't allow this and its a pain to service my carrier with my current setup<br>Thanks for your time View answer
Will these knuckles fit a Dana 44 IFS from late 80 through early 90's? I actually own a 93 Ranger 4x4 with Dana 35, but have read about the advantages of converting to 44 knuckles and outer stub shafts for the improved wheel bearing spacing and axle strength. I like the appearance of your product and was very curious about their interchangability with a stock Dana 44 IFS knuckle? A second question, can the top ball joint boss be milled to accept a standard Dana 35 upper balljoint.<br><br>Rob View answer
