Door Latch Rod | RH Passenger | Lock Knob/Latch | 68-77 Ford Bronco Q&A
Will these bolt into the original holes on 66 to 77 bronco's? View answer
My latch keeps gets stuck in lock position. I replaced the latch but still have same problem. It pulls up but not all the way and I have to push the little toggle on the bottom of the latch to get it to come all the way up and unlock. Do you think it's just this rod that needs replaced? View answer
what is the difference between #3639 and #3635? View answer
