M1A1 Stainless 23 Gallon EFI Fuel Tank | In-tank Pump | 66-77 Bronco Q&A
What size hose does the filler take? View answer
Asked 11 ´months ago
Is a body lift recommended for the installation of the 23 gallon tank? View answer
In reading the answer to a previous question, it sounds like the included fuel pump runs at 90 psi. But the Edelbrock Pro-Flo 4 system requires 43-45 or 58-60 psi. Is the included fuel pump pressure adjustable, or, is there an option to order the M1A1 tank with a fuel pump that is compatible with the PF4 system to avoid using a fuel pressure regulator? View answer
What size fuse should I use on the fuel pump circuit? View answer
How many GPM is the pump rated for, verses the other 23 gallon tank. View answer
