Front Disc Brake Conversion Kit | Dana 30 & Dana 44 | 66-75 Ford Bronco Q&A
What brand is the brake pads? View answer
Asked 11 ´months ago
I'm running the 3005netw on a 71 Bronco. scraping noise developed on drivers side when applying brakes yesterday. Pulled wheel and found that both caliper pins ( long pin with threads near hex nut that run from one side of caliper to other) were missing. Is it possible to purchase these individually? Thanks! View answer
Will this kit fit under the original 15 Ford rims? View answer
Is the caliper bracket and the rock guard one piece? View answer
How long are the lugs on these rotors? View answer
