WH Frame Mounted High Pressure EFI Fuel Delivery Kit | 66-77 Ford Bronco Q&A
Can I use this setup w a Coyote motor? View answer
Also can this be used with a 2 tank system with a manual valve? View answer
Asked 11 ´months ago
EFI Fuel Delivery Kit with Frame Mount Pump | Early Bronco Rear Tank Reliable Fuel Delivery for your Early Bronco EFI Conversion. Fuel your EFI swap the right way with the WILD HORSES EFI Fuel Delivery Kit, designed specifically for the rear fuel tank on 1966–77 Ford Bronco. Whether you’re running a...
