Dana 20 Transfer Case Detent Ball & Spring Kit | 66-77 Ford Bronco Q&A
Can this be done without disassembling the transfer case? View answer
What is the diameter of the balls? View answer
HD Early Bronco Dana 20 Transfer Case Detent Springs & Balls Keep Your Bronco in Gear with Confidence! Over the years, the Dana 20 transfer case found in early Broncos can start popping out of gear due to worn-out springs. Originally rated between 91 and 113 lbs per inch, these springs can weake...
