Throttle Linkage Kit | SBF 289 302 351W V8 | 66-77 Ford Bronco
Early Bronco Throttle Linkage Assembly | Ford 289, 302, 351W This OEM-Style Throttle Linkage Assembly is a complete, upgraded solution for your 1966–77 Ford Bronco running a 289, 302, or 351W V8. Designed to replace your factory throttle connection from the pedal to the carb, this 3-piece kit includ... See More
