Steel Tilt Steering Column | Floor Shifter, 2-inch OD | Universal
Ididit Universal Steel Tilt Steering Column for Floor Shifter Transform your driving experience with the Ididit Universal Paintable Steel Tilt Steering Column, designed for floor shifter setups. This GM-based column is crafted to bolt directly into the under-dash mounting location of your 1966-77 Fo...
