3-speed Floor Shifter Tunnel Cover | Steel | 66-77 Ford Bronco
Early Bronco 3-Speed Floor Shifter Tunnel Cover Finish your 3-speed floor shifter conversion with this steel tunnel cover, designed specifically for 1966–77 Ford Bronco. Whether you've installed a Hurst floor shifter or any traditional 3-speed floor shift setup, this cover is the perfect solutio... See More
