Rear Center Brake Hose for Lift | Stainless | 78-79 Ford Bronco & F150 4WD Q&A
Extended Rear Center Brake Hose for Lift | 78-79 Ford Bronco & F150 4x4 This rear center brake hose connects the brake hard lines on your 1978-79 Ford Bronco or F150 4WD frame to the brake lines on your rear axle housing. This hose is extended to support suspension lifts up to 7-inches. Res...
