Speedometer Drive Gear Clip | 66-91 Bronco, 57-91 Ford Truck Q&A
Is this a replacement for the tab and bolt on the Dana 20 T Case? View answer
what is the ID of the center bolt hole?<br>Thanks View answer
Asked 12 ´months ago
Speedometer Cable Drive Gear Clip | 1966-79 Ford Bronco This factory-style speedometer cable drive gear clip is a critical piece of your speedometer gauge's functionality. This clip ensures your speedometer gear stays locked in place at the transfer case end of the cable. Whether you’re restorin...
