Speedometer Cable | OE Type, 72.5 inch | 66-77 Bronco, 57-72 Ford Truck Q&A
Early Bronco Speedometer Cable If your early Bronco speedometer is not reading properly or is bouncing around as you drive, there is a solid chance the speedometer cable has failed. This new speedometer cable fits all 66-77 Ford Broncos with stock transmission and stock Dana 20 transfer case setups....
