Door Hinge Shim Kit | Stainless, Does 1 Hinge | 66-77 Ford Bronco
Early Bronco Door Hinge Shim Kit | Single Door Hinge Dial in your door alignment the right way with this Door Hinge Shim Kit, designed specifically for the 1966–77 Ford Bronco. Crafted from durable stainless steel, this kit includes enough shims to adjust a single door hinge, giving you the ability ... See More
