Rear Main Fuel Tank Master Kit | OE Type | 66-76 Ford Bronco Q&A
What do you use to cap the evap tubes that I will not use on my 1967 View answer
I have a 67 bronco. The rear filler neck has the vent tube in front of the main filler neck. Also, my old fuel tank had the vent tube to the front. When I look at the replacements, the vent tube is rear of the main filler neck, and also on the new stock style replacement tanks. Can I use my old filler neck with the new stock style replacement tank that has the vent to the rear? View answer
Is this tank made with galvanized steel? View answer
Do I need to use the skid plate with this tank View answer
Is this tank painted or powder coated? View answer
