Rear Main Fuel Tank Filler Hose | 66-77 Ford Bronco Q&A
Which filler hose do I need for the M1A1 tank? View answer
What is the difference between item # 1390 and 1396? View answer
Early Bronco Fuel Tank Filler Hose Replace the old fuel filler hose on your 1966-77 Ford Bronco rear main tank with a new fuel-rated filler hose from WILD HORSES. Typical Early Bronco Fuel Filler Hose Dimensions 66-76 Ford Bronco: 1.75" ID Straight Hose 1977 Ford Bronco (Factory Tank): 2.00&quo...
