Proportioning Valve Frame Mount Bracket | 76-77 Ford Bronco
Early Bronco Disc Brake Proportioning Valve Bracket Whether you're restoring your factory brake system or adding disc brakes to a 66-75 Bronco, this Disc Brake Proportioning Valve Bracket is a direct-fit solution. Patterned after the original OEM bracket, it bolts directly to the stock disc brak...
