Power Steering Pump | 351M 400M | 78-82 Bronco, 77-82 Ford Truck Q&A
Hello what is the pressure fitting size and type on the back of the pump? I swapped a 2004 f350 axle and steering box into my 1979 f250 with a 400m. I am running a mid 90's ford stock pump that is the same size and type as the 79 but has metric fittings. If it is the standard fitting do you have an adapter available? View answer
Will this kit work with a 460 swapped 79 bronco? View answer
I just bought a 1978 Ford Bronco. While driving it home the power steering went out completely. Looking on fullsizebronco.com this site came up a couple times. <br><br>This kit I will be able to pull my current PS pump and bolt this right on? Are there any other parts I need to get this going? This looks like it has the reservoir on it. Sorry if this is a dumb questions. Just getting into rebuilding and restoring. View answer
Will this kit work for a 81 F150 351m stock? View answer
Will this kit bolt up to a 96 Full Size with the 5.0? View answer
