Power Brake Kit with Wilwood Black Tandem Master Cylinder | 66-77 Ford Bronco Q&A
Will this setup interfere with the 5.0 upper intake ? View answer
i have been using this kit no 3071, i realize i purchased it about 4 years ago. The booster appears to be leaking pressure when the brake is applied. I removed the boot over the push rod and had someone hit the brakes and i can here it leak. DO you offer a replacement booster that i can purchase or know where i can find one that will last? View answer
what is the bore on the wilwood MC? View answer
