Dana 20 Transfer Case Adapter | NP435 T18 4 speed Manual | 66-77 Ford Bronco
Early Bronco NP435 to Dana 20 Adapter This adapter kit will allow you to adapt a New Process NP435 transmission into your 66-77 Ford Bronco with the factory Dana 20 transfer case. This adapter kit is designed for use with NP435 transmissions out of Ford F100, F200, F300 & 1-ton trucks with the F...
