Metal Fuel Filler Neck | Main (Rear) Tank | 66-76 Ford Bronco Q&A
I have a 77 and am replacing the lower quarters and at the same time removing the reserve tank. I do not want to use the filler door for the new quarter. Will this part allow me to go to the 76 and prior style filler with exposed cap? I am also installing your 23 gallon tank with EFI pump. Thanks! View answer
Fuel Filler Neck for Rear Main Tank | 1966–76 Ford Bronco Factory Fit. Reliable Flow. Built for the Long Haul. Replace your old, worn, or rusted filler neck with this OE-qulaity steel rear main fuel filler neck, designed specifically for 1966–76 Ford Broncos. Built to match the 1971–76 style with a ...
