M1A1 Stainless 23 Gallon EFI Fuel Tank + Skid Plate | In-tank Pump | 66-77 Bronco Q&A
In reading the answer to a previous question, it sounds like the included fuel pump runs at 90 psi. But the Edelbrock Pro-Flo 4 system requires 43-45 or 58-60 psi. Is the included fuel pump pressure adjustable, or, is there an option to order the M1A1 tank with a fuel pump that is compatible with the PF4 system to avoid using a fuel pressure regulator? View answer
Overall height, width, and depth measurements, please! Thanks! View answer
do you have a EFI in tank gas tank that isn't stainless? View answer
What's the difference between 9664stnet and 9664sknet ? Thanks, Rich. View answer
Asked 12 ´months ago
Is the heavy duty skid plate available separate from the fuel tank? View answer
What is the availability of this tank? Thanks View answer
Does this tank work with a trailer hitch? View answer
How many GPM is the pump rated for, verses the other 23 gallon tank. View answer
