M1A1 Stainless 23 Gallon EFI Fuel Tank + Strap Mount | In-tank Pump | 66-77 Bronco Q&A
Will the stock filler neck work on this tank? View answer
Does this tank need to be painted or is it good as is. View answer
M1A1 Stainless Early Bronco 23-Gallon EFI Fuel Tank w/Strap Mount WILD HORSES has launched the Early Bronco fuel system into the modern age with the M1A1 23-Gallon Stainless Steel Fuel Tank. Built from 14-gauge stainless and fully TIG-welded with true craftsmanship, this tank ditches rust, distortio...
