Lower Windshield Frame Hinge Seal | 66-77 Ford Bronco Q&A
Does this go under the hinge, or in the middle of the hinge. Thanks. View answer
Does it need to be glued into place View answer
Early Bronco Lower Windshield Frame Hinge Seal Don’t let a small leak become a big problem—this Lower Windshield Frame Hinge Seal is a critical barrier between the elements and your dash electronics. Designed specifically for 1966–1977 Ford Bronco, it installs between the windshield frame and body h...
