Large Rear Axle Bearing | 66-79 Ford Bronco, 53-79 Ford Truck Q&A
Are these Timken bearings or standard? View answer
What is the inside diameter? View answer
Rear Axle Bearing | Large (3-1/8" OD) | 66–79 Bronco, 53-79 Ford Truck Keep your classic Bronco or Ford truck running smooth with this Premium Quality Rear Axle Bearing, designed for 1966–79 Ford Broncos and 1953-79 Ford F-Series Trucks equipped with the Ford 9-inch small-bearing axle housing. ...
