IDIDIT Direct Fit Tilt Column, Chrome, A/T Column Shift, 76-77 Bronco Q&A
What size port adapter on the high pressure fitting should use View answer
What psi does this pump put out? I have hydro boost brakes and am concerned. Also does this pump have a lower mounting location on the back of the pump? Most saginaws do, just confirming. Lastly, is this the same as your 2012a pump....the sag pump with dual returns and no pulley? This is going on a 1979 bronco with a 460. Thanks View answer
