Heater Switch Cable | 66-77 Ford Bronco
Early Bronco Heater Fan Switch Cable Replace your 66-77 Ford Bronco with this direct replacement heater fan switch cable. This cable mounts to your dash, allowing you to control the heater fan speed and the outside air control door. The built-in electronic switch lets you select high or low fan spee...
