Gear Shift Arm | 1st & Reverse | 66-75 Bronco, 65-72 Ford Truck Q&A
How are they different? Is it just that they don't come with the shock mount? If so, that is fine as I am installing extended radius arms that relocate the front shock to behind the axle. I don't want to grind the shock mounts off of my stock ones. Dana 44 is a Dana 44 right? View answer
These should fit all the way up to 1979 correct? View answer
