Ford Small Block Test Bracket | 164 Tooth Flywheel or Flexplate
Small Block Ford Engine Test Bracket | 164-Tooth Flywheel/Flexplate This engine test bracket is designed for Small Block Ford engines equipped with a 164-tooth flywheel or flexplate. It allows for starter and engine testing without the need to install the bellhousing, making it ideal for diagnosing ...
