Dana 20 Transfer Case Adapter | Ford AOD 4WD Automatic | 66-77 Ford Bronco Q&A
What's the difference between this kit and item #8330? View answer
Will this adapter work between a 4R75E and Dana 20? View answer
Early Bronco AOD Automatic Transmission to Dana 20 Transfer Case Adapter Fits ALL 4WD Ford AOD Transmission Looking to add an automatic overdrive transmission to your Early Bronco? This AOD to Dana 20 Adapter is just what you need to pair your classic Bronco with a modern 4WD Ford AOD transmission. ...
