Ford 9-inch Crush Sleeve Eliminator Kit | Solid Spacer With Shims
Ford 9-Inch Pinion Crush Sleeve Eliminator | Solid Spacer w/ Shims Upgrade your Ford 9-inch differential with confidence using our Solid Spacer with Shims Pinion Crush Sleeve Eliminator Kit. Instead of relying on a traditional crush sleeve — which can deform over time under high torque — this solid ...
