Ford 302 to AX15 5-Speed Transmission Adapter Kit
Ford 302 to Aisin AX15 5-Speed Manual Transmission Adapter If you’re upgrading your Early Bronco or other classic Ford for better drivability and modern gearing, the Ford 302 to AX15 Adapter Kit is your key to a clean, strong drivetrain conversion. This adapter allows the proven Ford 302 small block...
