FlowKooler Water Pump | SBF 289 302 351W V8 | 66-77 Ford Bronco Q&A
Does it come with the backing plate and both gaskets? View answer
Is this the standard rotation pump for v-belt setups? View answer
Does this come with the gasket(s)? Thanks! View answer
What size is the is the bypass hose inlet/outlet ? 5/8 or 3/4 View answer
is the inlet on the passenger side View answer
What bolt size is used for the pulley bolts ? View answer
What is the length of the 5/16 x 24 bolts for the pulley fan View answer
Can this be painted? View answer
Asked 10 ´months ago
Does the water pump come with a new backing plate? View answer
Can you guys do next day air or second day air shipping to Minnesota View answer
