Hose Fitting | 6AN x 16mm x 1.5 upper O Ring | For use with 5.0 pump
Hydraulic Fitting | 6AN Male to 16mm x 1.5 Upper O-Ring This 6AN male to 16mm x 1.5 upper O-ring fitting is the go-to solution for plumbing the Ford C2 plastic power steering pump found on many late-model 5.0L engines. Designed for tight, leak-free connections, it’s the ideal choice for custom fuel ... See More
