Hose Fitting | 5/8-18 x 5/8-18 Inverted Flare | Sag/Del Pump to OE Pressure Hose Q&A
What is the spring rate of these springs? View answer
can you give me the inside and outside diameter of the coil springs. View answer
What is the loaded height of these 4.5 inch lift coils? View answer
I am looking for power steering gear fittings for my stock 1976 Bronco. I will be putting a hydro boost system. <br>I need the fittings to adapt to 6AN.<br>My pressure size is 11/16-18 inverted flare.<br>My return is 5/8-18 inverted flare.<br>I see your F2965 is what I need for the pressure but I don't see the 5/8-18 inverted flare to 6AN.<br>Did I miss it? View answer
What's the unloaded height of these 4.5 inch lift coils? View answer
