EFI Frame Mounted Fuel Pump | 125 psi | 38 gph - 144 lph Q&A
Will this work with the Edelbrock Pro-Flo 4 sold here. View answer
What size are the barb connectors on this pump (1/4, 5/16, 3/8)? View answer
Is this the only pump you need to run stock efi, or do you have to use a high volume low pressure pump to pull the fuel out of the tank to supply this one? I have done one other efi swap before and had to use two pumps, one to draw the fuel out of the tank and one to supply the high pressure to the fuel rail. View answer
