Door Hinge Shim Kit | Does Four Hinges, Stainless | 66-77 Ford Bronco
Deluxe Early Bronco Door Hinge Shim Kit Easy door alignment on your early Bronco with our Deluxe Door Hinge Shim Kit. When installing new door hinges, proper alignment is crucial for smooth operation and a factory-fresh fit. This door hinge shim kit provides all the shims you need to align both door...
