Dana 20 Transfer Case Rear Output Shims | 66-77 Ford Bronco
Early Bronco Dana 20 Transfer Case Rear Output Shims Dial in your Dana 20 transfer case with precision using this set of Rear Output Shims. Designed specifically for 1966–77 Ford Bronco, these shims allow you to properly adjust the preload on the rear output shaft bearings, ensuring smooth, long-las...
