Collapsible Lower Steering Shaft | Custom Built | 66-77 Ford Bronco Q&A
Ive had my custom steering shaft installed fir a few year and love it. The one thing about it I'm not sure if its right or not. The shaft is completely compressed together when installed, which leaves no room for compression in the event of a front end collision. Should I shorten the sleeved upper segment? If so how much? View answer
Will this work as is with a 2 body lift or do I need a longer length? View answer
