Baja Custom Roll Cage | 2.375 inch OD, Fully Welded | 66-77 Ford Bronco
Baja Custom Early Bronco Roll Cage Fully welded. Heavy duty 2 3/8" x 3/16" wall tubing. The Baja cage is a six point cage with dual inside and dual outside supports from the front hoop to the main hoop. It comes to you as bare steel so you can paint it the color of your choice. Why do our ...
