Clutch Flywheel | 50 oz Balance, 164 Tooth | SBF 5.0L V8 | 66-77 Ford Bronco Q&A
Early Bronco Clutch Flywheel - 50 oz Balance for Late 302/5.0L This 50 oz. imbalance, 164-tooth flywheel is essential when upgrading your early Bronco to a late-model Ford 302/5.0L engine. Designed for modern diaphragm-style pressure plates, this flywheel will not work with the factory 3-f...
