Adjustable Track Bar | XD 4140 Chromoly | 78-79 Bronco, 76-79 Ford F150 4x4 Q&A
What is the length of this track bar, center-to-center? View answer
What are the mounting hole sizes on both ends. Thanks View answer
XD Adjustable Track Bar | 4140 Chromoly Steel | 78–79 Bronco, 76–79 F150 Built from 4140 chromoly DOM tubing, this adjustable track bar is the heavy-duty solution for dialing in proper front-end alignment on a lifted 1978–79 Bronco or 1976–79 Ford F150 4WD truck. With an adjustment range o...
