Automatic Flexplate | 28 oz, 164 Tooth, C4 AOD 4R70W | 73-77 Bronco, 73-79 Truck
Early Bronco C4 Automatic Flexplate | 28 oz Balance | 164 Tooth This 28 oz balanced flexplate is the perfect replacement for 1973–77 Ford Broncos running a factory-style C4 automatic transmission and small block engine. With 164 teeth and the correct 11-3/8" torque converter bolt pattern, it de... See More
